Hello, Looking for some advice here. I am wondering if anyone could help me with a recommendation for someone coming from like 16 years of using Traktor Pro. Testing and I'm really liking the audio engine and all the possibilities with VDJ. I also use 3-4 decks regularly and play b2b with my wife out at club gigs. We use an Allen and Heath Xone 96 with 3(soon to be 4) K2's and a Midifighter Twister. It's a lot to try to process though as there are so many options and trying to get used to new controls. I feel the K2 mapping is really limited compared to my Traktor mappings, but again, audio first. Also want to be able to plug in to Pioneer gear and roll straight away when we can't muscle our setup into the booth at gigs out.
Anyways, wondering if anyone can help recommend a good layout, that shows 4 full decks like Traktor and won't be so tough to get used to. Anyone have experience of moving from Traktor Pro like this or have a good recommendation? Thanks in advance
geposted Mon 09 Jan 23 @ 11:45 pm
the best skin to use is always the default. use the layout dropdown menu at the top to customize.
geposted Tue 10 Jan 23 @ 2:11 am
One of my issues with that is that I can't get 4 full decks to show in the perfromance mode etc. Also the matching in the ryhthm section won't show all 4 in the same area. Or am I mistaken?
geposted Fri 13 Jan 23 @ 3:40 pm
there's performance 4 deck full vertical.
if you want 4 deck full horizontal it would be a skinning job
geposted Fri 13 Jan 23 @ 4:02 pm
4 full decks 4 full waves, still issues to work out
geposted Sat 14 Jan 23 @ 10:07 pm
