Topic: Flx4 home plus licence
TazrokHome userMember since 2022
Now vdj has support for the ddj flx4 I was looking to buy the home plus licence but can't see the flx4 in the drop down menu.
Am I doing somthing wrong?
Thanks
geposted Wed 18 Jan 23 @ 6:49 pm
A PLUS license will be available as soon as the current "Early Access" build goes to "Public" build status.
geposted Wed 18 Jan 23 @ 8:30 pm
OK thanks mate. I take it there is no date on that yet?
geposted Wed 18 Jan 23 @ 9:23 pm
Most likely within the next 5 to 10 days
geposted Thu 19 Jan 23 @ 9:57 am
OK brilliant thank you mate
geposted Thu 19 Jan 23 @ 8:18 pm
LIMOLPRO InfinityMember since 2003
Hello
I don't know if you can buy the home license here but it would be nice to try.
geposted Mon 23 Jan 23 @ 4:44 pm
I'll have a look at that mate. Thanks
geposted Tue 24 Jan 23 @ 4:30 pm
Just looked on mine and I don't have the flx4 on the list
geposted Wed 25 Jan 23 @ 7:43 am
As said above, the Plus license will be available when current Early Access Build becomes Public. Be patient for a few more days.
geposted Wed 25 Jan 23 @ 12:02 pm
I have the same issue, and have searched to find the answer, and still yet to receive one that resolves the question.
Does VDJ work properly with DDJ-FLX4?
It does not show in the drop down menu on the licence page.
geposted Thu 18 May 23 @ 8:21 pm
Yes, I can easily find the FLX4 in the drop-down.
And has been available to be purchased with a controller license, since the 7445 update, Feb 15th 2023.
One can see how the controller has been configured. See the reply in your other thread on the topic.
https://www.virtualdj.com/forums/252673/VirtualDJ_Skins/Pioneer_DDJ-FLX4_Support___Skin.html
groovindj wrote :
All you should need to do is plug it in (assuming you're running a new enough version of VDJ).
https://www.virtualdj.com/manuals/hardware/pioneer/ddjflx4.html
You will also need a license if you wish to use it continuously.
Check the manual, found here:
for every detail of how it has been configured.
If there a specific concern/question?
One is able to try the controller for a 30 day free trial. After month, free trial, the controller will operate for 10 min.
So you can be assured it will work to your liking, before the purchase of the license.
PS:
And unlike the software that comes with the controller, VDJ can be so easily configured to actually suit exactly the way you wish to use every knob, and button on the controller.
Actually allowing you more capabilities/control, then the controller was designed for. For example stems control..etc, and about almost anything one can imagine.
geposted Thu 18 May 23 @ 8:43 pm
