I used to use a DJM-900 mixer and I loved how I could trigger a reverse signal down in the mix. Virtual DJ has a nice "reverse" button feature, but is there a way to blend this reverse signal against the original (so it's more of a subtle effect rather than in your face)?
geposted Wed 25 Jan 23 @ 11:30 pm
I understand the idea, but it doesn't work, you have to call reverse at the right millisecond of half way between beats, you could make a thing but would still need prodding to be on time, and even then beat grids perfectly aligned; reversed still wouldn't be good, forwards the beat grid is the "U" of thump, reversed you'd get a bit of "M"
geposted Wed 25 Jan 23 @ 11:50 pm
Thanks for the response. Considering I am not concerned about the timing issues you mention, how would you go about making a "thing".
geposted Thu 26 Jan 23 @ 7:38 pm
