Hi,
I have purchased four LC6000 to use as a controller for Virtual DJ with my MacBook Pro, I connect them though a powered USB hub. I have a four channel club mixer as well, without USB input unfortunately.
I managed to connect the controllers easily with my Macbook, but the output is not working. I have four external soundcards (USB to RCA) that are also connected to my powered USB hub but I cannot make them work. Only one channel is operational at a time. Is it a setting on Virtual DJ or on my MacBook that I need to configure?
I want to have the configuration as SETUP 5 in Denon DJ’s recommendation:
https://d1jtxvnvoxswj8.cloudfront.net/wysiwyg/denondj/pdp/lc6000/LC6000_Setup_Options_2.jpg
geposted Thu 26 Jan 23 @ 10:42 am
You must configure the 4 outputs in the Audio Setup of Virtual DJ
Deck1 Soundcard one, Deck2 Soundcard two....
geposted Thu 26 Jan 23 @ 11:48 am
