So I have several karaoke files that are Multiplex (The Instrumental on the Left side and the Instru/Vocal on the right). I figured if I do Mono Mix plus the "Balancefader" effect to the left (or 0%) I can get the track to play the instrumental only on both channels. I would like to program both the mono-mix and the Balancefader Left to a "USER" button to simplify the process. I have been messing around with the programming settings but with no success.
geposted Sun 29 Jan 23 @ 8:48 pm
SBDJ made the thing you want
see stereochannel
https://www.sbdj.co.uk/plugins/
see stereochannel
geposted Sun 29 Jan 23 @ 8:55 pm
