Hi, I need some advice. I would like to map the mix FX buttons 1-4 on the filter on the hercules 500. I would like to choose my own effects... Specifically loop roll. Unfortunately, I still can't do it. Can you advise which command I should enter for the appropriate button? Thank you very much
geposted Mon 30 Jan 23 @ 10:57 pm
deck all filter_activate 'Noise'
that's an example of the current script.
geposted Tue 31 Jan 23 @ 2:54 am
maybe you try with
-----> filter_selectcolorfx "loop roll"
(and so on)
(and so on)
geposted Tue 31 Jan 23 @ 10:36 pm
Thank you very much 🙏🙏🙏
geposted Wed 01 Feb 23 @ 8:33 am
