Hello everyone :)
I seek thy knowledge.
i am trying to create a reverse slip roll but ain't getting to find a good tutorial to that.
In the Pads editor i tried to do the "dump when_pressed" but with that i only get the track tempo as reverse.
I want to do the same as with "normal" slip rolls -> 1/4 , 1/2 , 1 , 2 but in reverse.
all ideas are very welcome.
geposted Wed 01 Feb 23 @ 11:18 pm
dump when_pressed & loop 0.5 while pressed
geposted Thu 02 Feb 23 @ 5:47 am
That was great help already, thanks a lot!
Now, if i type in all that for 1/4 to 2 beat rolls, the slip funktion does only work, if i use it for f.e. one loop of 2 beats.
then the track jumps to the location the marker is at, at that time. which is what i wanted.
but if i continue to press the pad, to repeat the reverse roll, the marker continues to travel onward, yet the track does not jump to the position But instead to right behind the part where i started the roll.
how would i solve that?
Huge thanks again <3
geposted Thu 02 Feb 23 @ 10:39 pm
