Topic: not able to use pioneer srt 1000 to its fullist
pioneer srt 1000 not working well with vdj pro 2020, i runnig a mac book pro 2019
please help thank you
geposted Sat 04 Feb 23 @ 10:53 pm
djsh69PRO InfinityMember since 2018
Do you really think you provided enough informations that somebody can help you?
What are your concrete problems?
Not working at all?
No audio?
latency? glitches?
I think there was another thread here in forum describing major differences between the 1000 and the 1000srt,
mainly related to mixer section. maybe you find something there …
geposted Sat 04 Feb 23 @ 11:08 pm
Ok I’m sorry, here are more details that might help. The master volume doesn’t work at all and the sampler isn’t working either.
geposted Sat 04 Feb 23 @ 11:15 pm
geposted Sat 04 Feb 23 @ 11:21 pm
geposted Sat 04 Feb 23 @ 11:30 pm
Master Volume knob, is a HARDWARE operated control.
Therefore:
A) It will send MIDI data to VirtualDJ but it will NOT affect it's sound. (It's used only to show the movment of th knob on screen)
B) VirtualDJ's "master volume knob" does not have any effect on master output of the controller
C) If you move the master volume knob on your controller and it doesn't affect the sound, then the volume knob itself is most likely to be broken
More or less, same rules apply for sampler.
On DDJ-1000SRT, sampler output is routed on it's own channels. Then you control the volume of the sampler from the controller itself (SAMPLER VOLUME knob (18)) and the operation is hardware controlled.
https://www.virtualdj.com/manuals/hardware/pioneer/ddj1000srt/layout/mixer.html
geposted Sun 05 Feb 23 @ 4:20 pm
