I have prepared so far only 4 songs and save the stems in \Prepared Stems folder.
My question is why or how that folder is populating EMPTY FOLDERS ?
Before it was only the 4 folders from the prepared stem songs, now I have over 100+ folders and those folders are BLANK (empty).
geposted Thu 09 Feb 23 @ 4:24 pm
Any insights to this ?
I check the folder and it's still growing (over 270+ now).
Still only have 4 Stems created.
I manually create stem only when I need too. Not set to Auto.
My Lappy will crawl if I had it setup to Auto Create.
I turned it off and only turn it on when I need to prepare a song.
geposted Thu 17 Aug 23 @ 10:02 pm
May need more info, before the amazing team at VDJ can help more.
1) Screen shot of all the empty folders. Where are they located?.
2) Screen shot of OPTIONS, with "stems" in search box. (showing all your stems settings)
Did you possibly wish to save stems not in default location (the folder of the original track)?
3) Your OS and current VDJ version. (found bottom left of settings)
I currently cannot reproduce what you are describing. And having saved thousands of Stems.
More info is required for others to reproduce.
win 10
7617
win 10
7617
geposted Thu 17 Aug 23 @ 10:31 pm
Yeah, that sounds weird, are the empty folders numbered?
geposted Thu 17 Aug 23 @ 10:42 pm
