The VirtualDJ LE program for MAC, downloaded from https://www.virtualdj.com/le/ turns out to be 32bit and thus not runnable on a modern MAC. Is there a 64bit version out there somewhere? (I know that the VirtualDJ software is 64bit, but as far as I could figure out it does not support LE license activation.)
Sorry, if this isn't the right place to ask this, I'm new here.
geposted Thu 09 Feb 23 @ 9:22 pm
If your controller came with a VirtualDJ 8 LE then you can simply use the latest version from https://www.virtualdj.com/download/index.html
If it came with a VirtualDJ 7 or older LE version, that is no longer supported, and you'll need to get a Pro or Plus license to use it with a more recent version of VirtualDJ.
geposted Thu 09 Feb 23 @ 9:45 pm
