How can this be accomplished. I'm using the BUTT encoder and need it to be able to read a text file for the song name.
BTW I cannot find the folder in my documents folder (my drive c:\ is a boot drive only so my d:\ drive is my program drive) i have a documents folder and such but no VirtuaDJ folder.
Thanks in advance for the help
geposted Sat 11 Feb 23 @ 4:03 am
settings options&tweaks click the cog in the bottom right corner of this window
in your home folder you'll find
...\VirtualDJ\History\tracklist.txt
that gives you your last played tracks and can be formatted with setting tracklistFormat
If you can't get it working from that then something could be made if using windows
geposted Sat 11 Feb 23 @ 4:16 am
Thanks man...I found it! Unfortunately even in settings it ia formatted as %author - %title but in the file itself it is formatted as "22:45 : Van Halen - Right Now" with the time.
And yes I'm on windows
geposted Sat 11 Feb 23 @ 4:25 am
I hope I'm allowed to post my own link here, but I wrote a program to solve exactly this problem.
https://www.christianwheel.com/post/titlestreamer-for-virtual-dj
geposted Sat 11 Feb 23 @ 10:16 am
Tantrix wrote :
Thanks man...
try
\n%author - %title
geposted Sat 11 Feb 23 @ 12:52 pm
locodog wrote :
try
\n%author - %title
Tantrix wrote :
Thanks man...
try
\n%author - %title
That fixed it ty so much! I wish I could code...lol
geposted Sat 11 Feb 23 @ 1:06 pm
Thanks for thelink buddy! logodog solved the issue but I appreciate your input.
geposted Sat 11 Feb 23 @ 1:08 pm
