hello,
Is it possible to clone the stems setting from one deck to the other.
Example I have a song in deck 1 with only the acapella on.
Then i can clone deck 1 to deck 3 and i want to clone the stems to so in deck 3 it is also a acapella.
I tried it with effect_clone but it does not clone the stems.
geposted Mon 13 Feb 23 @ 8:21 pm
Try this:
param_equal & action_deck 1 ? clone_deck 3 & deck 1 stem_pad 'acapella' & deck 3 stem_pad 'acapella'
geposted Wed 15 Feb 23 @ 12:11 pm
clone, cast all 3 eq values over to the new clone, if using stem pads, stem solo etc, open bracket, query a setting, apply result to new clone, close bracket, open bracket query a setting...
keep doing that until you have an identical clone
brackets make it really easy, no nesting in nesting in nesting
geposted Wed 15 Feb 23 @ 7:22 pm
param_equal & action_deck 1 ? clone_deck 3 & deck 1 stem_pad 'acapella' & deck 3 stem_pad 'acapella'does clone the song but does not clone the acapella.
@LOCODOG
I dont get it. Can you explane how to clone a stem. I have the stems on a rotery knob.
Is it someting like: deck 1 read stem "vocal" % set deck 3 stem 'vocal" %. ?
geposted Fri 17 Feb 23 @ 9:40 pm
