Topic: build 7462 Bug
all of my files have lost their waveforms in the browser since using this version or the one before.
it comes back when loading the files but why would it be gone?
geposted Thu 23 Feb 23 @ 8:34 pm
Perhaps you deleted your cache.db?
no i didn't delete it its there over 9 meg is size
could the drive letter changing for my external music drive cause this that's all i can find that has changed other than the virtual dj updates.
Change the letter of the drive the problem. The VirtualDJ Database works with absolute paths. When you change the letter the Database can not find the files.
I have seen it mentioned many time that the drive letter wouldn't matter and all the music is fine, the playlist i have created are fine, virtual folders Etc.
maybe it matter with the waveforms only? if so I'll live with it i guess.
