user18822178 wrote :
Don't know what you've done with the new update, (not mentioned in the changelog) but the Nvidia RTX3050ti 4 GB now works @ 11x speed! instead of 3-4 minutes before for a 5 minute track.
Fast enough for me to be workable with and faster then with the AMD Radeon!
So, good job guys!
So, good job guys!
Hi, can you share how to configure VDJ to achieve these results?
geposted Wed 17 Jan 24 @ 10:55 pm
update graphics driver and try again
geposted Wed 17 Jan 24 @ 11:43 pm
Still the same results. 1.3X.
do i need to change anything else?
geposted Thu 18 Jan 24 @ 7:42 pm
Then it's not RTX 2060, it's RTX 2050 and its dedicated VRAM is not high enough to handle Real-time Stems separation. Needs at least 6GB, yours is 4GB
https://virtualdj.com/wiki/Minimum%20system%20requirements.html
geposted Fri 19 Jan 24 @ 2:37 am
I understand the minimum specs required, but OP says he find a solution to make it through whit 4GB VRAM, so it's this possible whit RTX2050?
geposted Fri 19 Jan 24 @ 2:47 am
Indeed, works absolutely fine with 4GB for me. Go check out page 2 of this thread where I discuss the Windows Hardware Accelerated GPU settings. Changing that to force it to use the dedicated GPU (instead of the onboard graphics) solved my problem.
geposted Sat 20 Jan 24 @ 6:22 am
[/quote]Indeed, works absolutely fine with 4GB for me. Go check out page 2 of this thread where I discuss the Windows Hardware Accelerated GPU settings. Changing that to force it to use the dedicated GPU (instead of the onboard graphics) solved my problem.[/quote]
Sadly, this doesn't work for me either, please share NVidia driver version and VDj build to test correctly.
geposted Mon 22 Jan 24 @ 7:16 pm
Only 1.0 to 1.3Xcomputed speed achieved.
geposted Mon 22 Jan 24 @ 9:55 pm
after 3 windows installs, it seems problem was solved, already 10.x plus stems processing speed achieve. Also, 4gb VRAM in use, weird.
geposted Wed 24 Jan 24 @ 4:57 pm
Finally, it was fast enough to achieve 10x computing speeds.
geposted Wed 24 Jan 24 @ 5:37 pm
What did you do to achieve this?
geposted Wed 24 Jan 24 @ 8:47 pm
looks like you have to use this driver 551.23, (PhysX enabled) to achieve these results.
Last one driver i use doesn't work.
geposted Wed 24 Jan 24 @ 10:20 pm
