When I don't open VDJ for a while and then open it, it asks me to login again. This is problematic sometimes when I don't have internet connection and I just cannot use VDJ at all:
![](/img/376316/27810/Screenshot 2023-02-25 193232.png)
This happens even if I don't open it for a couple weeks, and I can easily go a couple weeks between gigs. I feel like there should be a way to permanently save your login info and use it in offline mode somehow.
How do other people get around this?
Thank you in advance.
geposted Sun 26 Feb 23 @ 3:37 am
Go into the Settings and tick this
![](/img/376318/18311/stayLoggedIn.png)
geposted Sun 26 Feb 23 @ 3:49 am
It's not asking you to log in.
The text states "Cannot connect to the servers" which is usually caused by having previously used a cracked version of VDJ on your system (which blocks the connection). You need to modify/clean your hosts file to remove the reference to VDJ.
https://www.virtualdj.com/wiki/checkinghostsfile.html
geposted Sun 26 Feb 23 @ 9:17 am
@groovindj Oops! Missed that cos the pic didn't show when I first saw this thread earlier this morning. Ah well. 🤷♂️
geposted Sun 26 Feb 23 @ 10:01 am
