Hello;
I own the Numark NV ii - On my controller, the volume sliders for deck 1 & deck 2 are broken so I can't use them; I'm trying to remap my controllers volume slider on channel 3 & 4 to control the volume for channel 1 & 2 in virtual DJ but I can't seem to specifiy the control per volume slider; VDJ seems to automatically detect which volume slider is being moved and automatically mapping it to the correct channel;
Any help would be great as this is the only thing stopping me from converting back over to VDJ from Serato;
Thank you
Thank you
geposted Tue 28 Feb 23 @ 4:25 pm
Volume Faders ( Mixer channel order is 3-1-2-4 decks). A different Mixer channel order can be selected from VirtualDJ Settings
geposted Tue 28 Feb 23 @ 5:17 pm
^ this will probably not work, the Mixer Order is not supported in this device (we ll add in future update), so for now you ll need to do a bit of remapping..
VOLUME key :
Similar actions , using action_deck x could be used for other keys like PFL, EQ knobs etc ..
VOLUME key :
action_deck 1 ? deck 3 volume : action_deck 2 ? deck 4 volume : action_deck 3 ? deck 1 volume : deck 2 volume
geposted Tue 28 Feb 23 @ 5:55 pm
