Hello. I own a old laptop so my stem are precomputed but not everything. I know there is a special logo beside the song title in the playlist saying if the song is precomputed but I wonder if I can see if it's precomputed on the deck while it'S playing. Because not every songs is precomputed it would be useful to know while the song is playing because now I need to remind the song in the playlist to figure it out because if it's not the stem separation won't be the same at all. Thank you
geposted Tue 21 Mar 23 @ 1:43 am
You could try this on a custom button
It will light up if the loaded track has stems.
If you are only using prepared stems then the ones that are not prepared will not light up the button.
has_stems 'ready'
geposted Tue 21 Mar 23 @ 2:10 am
I works for for stem 1.0 too. I would like list up juste if the stem 2.0 is precompute. thank you
geposted Wed 22 Mar 23 @ 1:23 am
has_stems "2.0" should do the trick
geposted Wed 22 Mar 23 @ 10:58 am
