Hi there,
I would like to find out is it possible to combine two commands into 1 MIDI function? I'm using the APC40mk2 and would like to map the crossfader to the normal crossfader and video crossfader at the same time. Is this possible? I would like to create a custom mapping instead of the original default mapping that is available. I'm also trying to figure out how to map the LED colors on the APC40mk2 for each command as well.
Could anyone help?
Could anyone help?
geposted Tue 21 Mar 23 @ 3:56 pm
Yes to have 2 or more scripts execute on one button, knob or slider, you simply put a "&" between the scripts
geposted Tue 21 Mar 23 @ 4:15 pm
roxwindy wrote :
...crossfader and video crossfader at the same time...
see
https://www.virtualdj.com/manuals/virtualdj/interface/mixer/video.html#videooutputmenu
it can do that as an option, but as klaus says &, strings commands together.
LEDs look at the mapping
geposted Tue 21 Mar 23 @ 6:01 pm
