hi guys i am really stuck, i have got virtual dj 8 and a numark controller, was at a gig last night and about a hour into the set my controller stops playing then after a couple of seconds kicks back in, it seems to crash and works again, so i had to disconnect the controller as it done it a few times that night, it never crashed just using the laptop, can someone please help its driving me mad thanks
geposted Wed 22 Mar 23 @ 12:26 am
it happens to me too. The controller just doesn't respond. If you re-plug the cable, it works again
geposted Wed 22 Mar 23 @ 10:35 am
Either a dodgy USB cable or Windows shutting down USB to save power which it does by default. This can be changed in Device Manager.
geposted Wed 22 Mar 23 @ 10:36 am
Why does Windows disable if signals are transmitted, buttons are pressed on the controller
geposted Wed 22 Mar 23 @ 10:40 am
I really don't know but it is a common issue.
geposted Wed 22 Mar 23 @ 10:52 am
Always seen it recommended, but indeed never seen any proof of it actually changing anything. (And indeed would be very strange that it's disconnected while data is transmitting)
geposted Wed 22 Mar 23 @ 10:55 am
How do you do this please, its annoying I have just reset my laptop and got rid of all setting and app back to default, downloaded all the latest drivers on the controller and any updates for Window 11, and still seems to do it not a lot but still there, got brand new wires for the controller to, theres nothing on the laptop running apart from virtual dj as I have just reset it any ideas lol
geposted Wed 22 Mar 23 @ 12:17 pm
geposted Wed 22 Mar 23 @ 12:19 pm
My specs om my laptop its more and capable for virtual dj
