PAD_MODE_HOTCUE_LONG interferes with the responsive splitting of the 8 pads for everything that involves the PAD_MODE_HOTCUE button. So for example Hot Cue split with Pad FX or Beat Jump or Sampler...
When PAD_MODE_HOTCUE_LONG is deleted, the split works just fine.
Can the FLX_10 MIC effects mapped to something else in the default mapping?
geposted Fri 28 Jul 23 @ 12:55 pm
Hey all- what is the current status with the FLX10 and VDJ? Is it completely reliable and functional now?
Thanks in advance.
Thanks in advance.
geposted Fri 10 Nov 23 @ 11:34 pm
Works fine. I would say go for it.
geposted Sat 11 Nov 23 @ 1:03 am
Hello friends! I just got the Pioneer FLX 10 and controller VU Meters are just not correct. As you can see in the video VDJ meters are not cliping, but FLX 10 meters stays in red zone. Master meters also looks not fine. Using latest VDJ version. Tell me please that the meters shouldn't act like that.
YOUTUBE VIDEO:
https://m.youtube.com/watch?v=fvkx0UjxcXo
YOUTUBE VIDEO:
geposted Wed 22 Nov 23 @ 8:02 pm
i can confirm, the meters aren't correct at all
also, after a while playing my stems+fx start to act wierd, not doing what it is supposed to do :(
geposted Thu 23 Nov 23 @ 7:19 am
About VU Meters...
Long story : Read this topic from Page 8 .. https://www.virtualdj.com/forums/251695/VirtualDJ_Technical_Support/Pioneer_DDJ-FLX10_Virtual_DJ_Support_.html?page=8
Short one : Map the VU METER key as .. get_level
Best solution : set zerodB setting in VirtualDJ to -6 (or lower)
geposted Thu 23 Nov 23 @ 7:33 am
djdad wrote :
About VU Meters...
Can confirm. Have mine at -9db and they work just fine.
However, the default is 0db and I don't think this should be the default.
geposted Thu 23 Nov 23 @ 7:42 am
Hi! Finally I have the flx10 and today I tested it.
I have been able to see that you have to lower the gain of each channel a lot so that it does not distort the sound. Master on 0 but if channels have mid position gain, music distort.
When I add new track to a channel the gain reset to mid. How I can disable auto reset gain when open new track and keep gain of the flx10?
geposted Tue 13 Feb 24 @ 11:44 pm
You should lower the zerodb setting inside VirtualDJ instead of keeping all gain controls to let's say 11 o clock position.
So, open settings, search for zerodb and set it at -6 or at -9 db
geposted Tue 13 Feb 24 @ 11:50 pm
Any have a list of all manual fixes with virtual dj and flx10?
geposted Wed 14 Feb 24 @ 6:20 pm
