Topic: DDJ FLX6GT FX Issue
I just got the FLX6 and I cannot find where to see what effects are assigned to the 6 fx triggers on the console. The manual says the GUI will update to show 6 fx selections but it does not.
Any help would be appreciated.
geposted Sun 26 Mar 23 @ 11:50 am
You can enable the 6 modes on the "dot" menu on the FX pane in the GUI
Then you click the FX pane button (the text) until you get to the 6fx mode
I enabled this option but it still does not give me an option to choose it.
first: select on the dot menu all what you want see
second: click to the panel button to cycle between your chosen panels
Ahh Sorry i see what you mean. There is no fx6 list.
Do you use the default skin? Whithout (Edit)?
I switch to PRO without EDIT and have the 6fx now. Thank you.
BUT I still see/choose/change the effects assignments or see them be triggered when using the flx6
I downloaded rekordbox and I can see everything there but not in VDJ.
very frustrating anyone more ideas?
ok so getting there. I see/control/change the fx when I have FLX6 ch selected to the specific channel but not when it’s on MST …is this a setting or something.
Now the above issue is solved how do I see the MERGE FX selection 1-4?
