Hi I'm looking to see if it possible to put a video on re loop, so it plays over again once finished?
geposted Mon 27 Mar 23 @ 2:55 pm
A few ways I could have sworn there was a script, I found relay_play but that's for 2 deck
near the very end of your video, place an action poi, action being
goto_start
goto_start
geposted Mon 27 Mar 23 @ 4:37 pm
If it's a short clip, like an ad or a jingle/drop, you could load it to the sampler, which offers looping.
geposted Mon 27 Mar 23 @ 4:39 pm
You can also get it to repeat from a cue point if you wish
geposted Mon 27 Mar 23 @ 4:41 pm
repeat_song on a custom button would also work to loop a specific deck
geposted Mon 27 Mar 23 @ 4:51 pm
I knew there was a script
geposted Mon 27 Mar 23 @ 6:05 pm
another way - if u only need to show the video and save used Decks - would be to drop the file to a sampler slot, open with Sampler Editor and then choose to Loop and disable its Audio.
then you can trigger the Video from the Sampler.
geposted Mon 27 Mar 23 @ 6:27 pm
another way [why not XD], put it in a loop
custom_button
custom_button
goto 0% & get_time "remain" "absolute" & param_cast "ms" & loop
geposted Mon 27 Mar 23 @ 8:09 pm
drag the video to the sample bank - open sampler editor and tell it to loop.
or just drag to automix and put it on repeat.
either way works
either way works
geposted Mon 27 Mar 23 @ 9:08 pm
