I thought I would test streaming to kick.com, and see how it works compared to Twitch
Signing up, and going through a few tutorials, they seem to work basically the same
They both depend on a rtmp URL and a stream key
For kick.com the URL is:
rtmps://fa723fc1b171.global-contribute.live-video.net
But for some reason Twitch works fine from VDJ, whereas Kick.com won't let me connect
Has anyone else tried streaming directly from VDJ to kick.com?
geposted Mon 27 Mar 23 @ 3:43 pm
Perhaps they need specific quality or other specs ?
geposted Mon 27 Mar 23 @ 6:31 pm
It doesn't seem to matter what format/quality I try
geposted Tue 28 Mar 23 @ 5:25 am
It works using OBS, using screen and audio grab from VDJ
- almost no matter what settings I use in OBS...
geposted Tue 28 Mar 23 @ 6:09 am
Getting back to this...
Is there a way I can log what is going on in the connection when VDJ simply says "Unable to open connection" and can't establish the connection to kick.com?
It doesn't seem to be the network, and it works with OBS
It should just be regular rtmps that is used
geposted Sun 23 Jul 23 @ 9:13 am
