Topic: New Hard Drive Help!
Hey- Still a novice to VDJ. Last year I got all my folders categorized. I upgraded to a bigger portable drive, copied every thing over so that they're in identical folders and now all my songs in the virtual folders are gone. I can plug in my old hard drive and they show up, but how do I get it to recognize those files on the new drive?
Thanks.
geposted Wed 29 Mar 23 @ 7:05 pm
Set the Drive-Letter to same as your old drive. Also the folder structure must be the same.
geposted Wed 29 Mar 23 @ 7:08 pm
How did you copy?
if you do the copy inside vdj it deals with it. If you copy outside vdj then then you've made work for yourself
geposted Wed 29 Mar 23 @ 7:10 pm
locodog wrote :
How did you copy?
Oh really? Yeah, I copied outside of VDJ. I've not gone too far with new music yet. I'll try copying things over.
geposted Wed 29 Mar 23 @ 7:13 pm
yeah copying outside does everything literally [if it says "C:\\" in the vfolder it copies that.]
copying inside it knows what a vfolder is and how it works, so it deals with those localisation issues.
geposted Wed 29 Mar 23 @ 7:21 pm
Ok- I copied everything over using the browser in VDJ, unplugged the old drive and the files did not stay. Did I do something wrong?
geposted Wed 29 Mar 23 @ 9:25 pm
