Would love to see the points where the BPM changes in a song in both the overview/main waveform and the scrolling one, so we can have a visual indication when the tempo is going to change without opening the BPM Editor.
geposted Sat 01 Apr 23 @ 6:39 am
+1
I assume you are referring to those points that the BPM changes after analyzing for variable BPM (or manually created)?
There are Beat Anchors (BeatGrid Anchors) set at each of those locations.
The Beat Anchors default to having an "Invisible" attribute.
Currently I open the POI Editor, and manually change each from "Invisible" to "Marker only".
Because "as you say" it is good to be aware of when the BPM may change.
I have previously "in a wish" asked that a check box be added to the BPM Editor, to so the Default behaviour of the created Beat Anchors could be also selectable to "Marker only".
As it would streamline the workflow.
(especially since "Invisible" and "Marker only", are the only attributes that cannot currently be addressed by scripts)
geposted Sat 01 Apr 23 @ 7:46 am
