Forum: Wishes and new features
Topic: Easy interface to Delete/Remove Persistent Variables
Would love to have an easy interface to easily Delete/Remove Persistent Variables (local and global).
One solution: Add a right click action menu, of the Persistent Variable from within VarList
Maybe even a select many mode, could be added also. (using Cntrl/Shift, for multiple selection, to remove all selected)
Currently the only way I am aware of is to edit the Setting/Option: VDJScriptGlobalVariables and delete that, persistent variable, and being careful to leave exactly 1 space after the comma.
(and of course one could also edit the settings.xml file)
Both of the above are NOT that easily accomplished.
Side Note:
why is the option labeled VDJScriptGlobalVariables and NOT VDJScriptPersistentlVariables since it lists all persistent variables (both local and global)?
geposted Sun 02 Apr 23 @ 4:35 am
