Hey
I need some advice and help concerning Virtual dj with a Pioneer DJ XDJ RX3.
Has anyone used them together?
Does it work well?
Do you need Rekordbox or by installing the Console does Virtual dj take over the Rekordbox role?
£1800 is a lot of money to spend if it does not work well.
Please can someone give me advice
Even if its recommending a different console all together
Does it work well?
geposted Sat 08 Apr 23 @ 3:40 pm
It is supported hardware.
https://www.virtualdj.com/manuals/hardware/pioneer/xdjrx3/layout.html
geposted Sat 08 Apr 23 @ 3:54 pm
Thanks For the reply, but does it work as well as the DDJ 1000 because the DDJ 1000 seems to be the favourite but they are hard to get hold of.
geposted Mon 10 Apr 23 @ 5:00 pm
I use one every 2nd week at the club I work. It is not as good as the XDJ-XZ. But in saying that, it does work well with VDJ. I use the "Hardware Mixer Mode" setup. That can be found here....
https://www.virtualdj.com/manuals/hardware/pioneer/xdjrx3/mode.html
geposted Tue 11 Apr 23 @ 11:12 am
Thank you!!
geposted Tue 11 Apr 23 @ 12:15 pm
