During testing the feature stems_split I experience a momentary audio gap (drop-out) when switching stems-split off. It's the same kind of audio gap which happened when the stems-effects were switched off when introduced some months ago, which is solved with update 4762.
I7 16Gb-ram / RTX2060super / W11 (desktop)
geposted Sun 09 Apr 23 @ 5:52 pm
I don't get gaps, but if I click it on /off fast (3-4 times per second), I can get a tiny "pop" sometimes
geposted Sun 09 Apr 23 @ 6:41 pm
@ Klaus
It's possibe that the audio dropouts vary per latency setting. I am using a Pioneer DDJ-RZX with a fairly large asio buffersize of 768 samples. When I vary the buffersize the time of the gaps vary also... Maybe this info helps with testing...
geposted Mon 10 Apr 23 @ 5:11 pm
