Topic: Stems Button mapping
Is it possible to map a custom button so that when you play the Stems vocals on one deck then it would automatically drop the vocals on the other? I cannot find anything anywhere to see how to do this, thanks.
geposted Thu 13 Apr 23 @ 7:04 am
only_stem vocal & action_deck 1 ? deck 2 mute_stem vocal : deck 1 mute_stem vocal
something like that should get you started
deck left play ? deck right match_bpm & deck right stem_pad Acapella & deck left stem_pad Instrumental & deck right play & crossfader 50% : deck right play ? deck left match_bpm & deck left stem_pad Acapella & deck right stem_pad Instrumental & deck left play & crossfader 50% : nothing
My version.
