Topic: 5 Knobs/Stems Mode on DJM900-NEXUS
adamPRO SubscriberMember since 2022
Had a gig the other night and decided to try out 5 Stems mode. Colour is assigned for the bass stem on channels 1 & 4 (outer), however it wasn't working with factory default mapping.
Midi signal was being picked up - from memory I think it came up as "COLOR", however it wasn't channel-specific.
How shall I assign it to make these spare channels be correctly assigned to the bass stem as outlined in the Equalizer Controls screen, but only when it's in 5 stems mode? It may be handy for future users if the default factory settings are updated to reflect also.
Many thanks!
geposted Sun 16 Apr 23 @ 2:54 am
Perhaps it's a limitation of VirtualDJ?
As far as I can see you can't avoid keeping the bassline in no matter what, unless you make separate mappings for separate Advanced EQ modes.
geposted Sun 23 Apr 23 @ 11:33 am
if it's mapped as 'filter' then it should work
Edit: Looks like it's currently mapped as var '$ColorFilter' ? filter : nothing so it seems like it would only work if filter is selected as color fx. You can alternatively just change the mapping to simply 'filter'
geposted Sun 23 Apr 23 @ 12:15 pm
