Iv got a pc and mac that I use my pioneer rev7 with but prefer my pc to dj with due to plugins and vj use, never had any problem with other controllers but the rev7 glitches from time to time with the pc.... dont have any problems when using mac or another controller... it did exactly the same on my old pc but really can't work put why ..... currently use a udg usb c to usb b cable .... and nkt getting hardly any cpu usage ....
Anyone else having this problem , thanks
geposted Sun 16 Apr 23 @ 7:25 am
I got the same issue, Have you found a solution since writing tthis
post?
post?
geposted Thu 11 May 23 @ 9:44 am
You need to give details. Computer spec, VDJ version, audio settings etc.
geposted Thu 11 May 23 @ 5:24 pm
