When a loop is playing is there any way to tighten the loop by moving the jog wheel forward and backwards?
geposted Tue 18 Apr 23 @ 12:52 pm
There is.
On some controllers (mainly Pioneer ones) this function is built in.
Otherwise you need to toggle the jogwheel between "loop adjust" and "normal" mode.
Use this on a custom button to get an idea: wheel_mode 'loop_in, jog' +1
geposted Tue 18 Apr 23 @ 12:56 pm
