Before anyone hounds me for my controller choice, I know it's not a full feature option but it fit my wedding DJ needs at this time and fit my starter budget. :)
Purchased in December but haven't had many gigs until just recently as it's been slow where I am. When controller is hooked to Mac and audio out of controller, I am getting a popping in the audio. I contacted Numark and they mentioned buffer settings but only how to adjust in Serato. I haven't been able to find it on VDJ.
Any help from anyone would be swell.
I took the audio from the MacBook to eliminate the popping but can obviously no longer cue songs in my headphones.
Thanks y'all!
Thanks y'all!
geposted Tue 25 Apr 23 @ 11:00 am
Check the latency setting in VDJ. I use my one at 512 (in Windows) and it's fine.
geposted Tue 25 Apr 23 @ 11:52 am
That’s where I am. Can’t find where to change or adjust.
geposted Tue 25 Apr 23 @ 11:55 am
geposted Tue 25 Apr 23 @ 12:32 pm
What number is recommended? Mine was in ZERO.
I also don’t have the ultra option like the screenshot.
Thanks y’all!
Thanks y’all!
geposted Tue 25 Apr 23 @ 2:04 pm
As I said above 512 works fine.
geposted Tue 25 Apr 23 @ 3:10 pm
Well, I've tried to adjust the latency and still pops. Any other ideas? I have it at 512 currently.
geposted Tue 25 Apr 23 @ 8:06 pm
