Topic: DDJ-XP2 INT_LED fix
hello ,
can you fix build in definition of DDJ XP2 INT_LED in next update. I tested it is work perfect. Defination Code is down bellow,
thanks, dj Koray,
<device name="PioneerDDJ-XP2" description="Pioneer DDJ XP2" author="djkoray01" vid="0x2B73" pid="0x0035" type="MIDI">
<button note = "0x73" name = "INT" channel="0" deck="left"/>
<led note="0x73" name="LED_INT" default="INT" channel="0" deck="left" />
</device>
geposted Thu 27 Apr 23 @ 8:01 pm
djkoray01 wrote :
hello ,
thanks, dj Koray,
<button note = "0x73" name = "INT" channel="0" />
<led note="0x73" name="LED_INT" default="INT" channel="0" />
</device>
geposted Fri 28 Apr 23 @ 6:36 am
geposted Fri 28 Apr 23 @ 6:37 am
It's not broken ?
I mean device definition has the LED_INT and it works in our device!
geposted Fri 28 Apr 23 @ 9:06 am
PhantomDeejay wrote :
It's not broken ?
Button is working But Led is not lighting
geposted Fri 28 Apr 23 @ 9:00 pm
