If I had a wish... could you please fix single deck automix, so it works as flawlessly as dual automix works?
I explain:
For my purpose I am using automix quite often. I prefer single deck for several reasons.
As automix type I am prefering the "radio" version, means "Fade out, cut in".
This works fine in dual automix, but it is quite useless in single deck automix.
Reason: in single mode each time when a song fades out (shortly before the next song kicks in), there is a sudden "drop" in volume that is disturbing a lot. Not a smooth fade out as a 16sec fade out time should produce, but a sudden fall that is irritating. In fact it is so irritating that I stopped using this transition mode all together.
Could you please fix this? This would be greatly appreciated!
Thanks!
I explain:
Thanks!
geposted Sun 30 Apr 23 @ 11:11 am
Looks like there was indeed a bug there if the next song didn't have any silence before the start
geposted Sun 30 Apr 23 @ 11:26 am
Thanks for your reply!
By saying “was”, does that mean that this issue has been resolved? I thought I’m using pretty much the latest version.
geposted Sun 30 Apr 23 @ 11:32 am
It has been fixed for the next update :)
geposted Sun 30 Apr 23 @ 11:46 am
Oh Yippie! Then my wish would become true... I feel like just before christmas.... :) so much looking forward to this release.
Thanks! Greatly appreciated!
geposted Sun 30 Apr 23 @ 11:49 am
HI Adion,
just saw BUILD 7544 (2023-05-02) being released. Tried it, but the issue described in my post does not seem to be fixed. Will there be another update coming soon?
Thanks.
Thanks.
geposted Tue 02 May 23 @ 8:29 am
Should be fixed in Early Access build 7547
geposted Wed 03 May 23 @ 5:42 am
Perfect!! Just listed through 20 songs and transitions and no issues, no audio drops.
THANK YOU!
THANK YOU!
geposted Wed 03 May 23 @ 6:23 am
