This may already have been reported/discussed/explained, not sure
But it seems that the Pitch color fx affects both channels/stems when using stems split
Shouldn't they be totally separated at that points?
It works with stems split unlink, so maybe pitch (including the color fx) is considered part of the linked stems, like cue, hotcue, scratch and so on
geposted Tue 02 May 23 @ 8:56 am
I confirm and I don't know if this is normal!
geposted Thu 04 May 23 @ 12:55 pm
I think maybe it's considered a timed option (because it has to stay in time, even when you change the pitch) - which means that you can only use it on split stems if you detached them (using stems_split_unlink after you use stems_split to split them)
geposted Sun 07 May 23 @ 12:11 pm
This could be the reason even though pitch as an effect does not alter the tempo of the song. How do you use stems_split_unlink to make it work?
geposted Sun 07 May 23 @ 9:36 pm
It's part of this video
geposted Sun 07 May 23 @ 10:09 pm
