Topic: Recurse missing after update
fsulikPRO InfinityMember since 2017
5/3/2023
Hi, I just updated my Virtual Dj to latest update this morning.
Usually when I right click on my music folder I can select recurse. however its missing after the update.
If I go to a subdirectory folder of the /music folder and right click recurse is there.
Not sure if this matters or not
geposted Wed 03 May 23 @ 3:12 pm
we'll check, but in the meantime you can right-click, set as Favorite Folder (will add at the bottom), then Recurse will be available in that Favorite Folder
geposted Wed 03 May 23 @ 3:41 pm
Same has happened here, no recurse option. No add to Search db either
geposted Wed 03 May 23 @ 8:56 pm
