I'm not sure if this is only specific to using the DJM S11 or not, but I did notice this while using the the Stems 2.0 pad page with the DJM S11 with the latest build (2023-m b7544):
The StemsFX button seems to change from selecting which part of the stems that FX apply, to actually selecting parts of stems (e.g. vocals, melody drums)
I seem to be able to make this happen by doing the following while a track is playing:
Once a new track is loaded and the process above is repeated, the StemFX button seems to change to an isolation mode, where it isolates the stem instead of selecting it for FX application. The behaviour seems to persist until VirtualDJ is restarted.
- Go to the Stems 2.0 pad page, and use the StemsFX button to select Vocals as the part to apply effects to
- Toggle an effect (e.g. Echo) using the paddles to trigger the effect on the stem
- Switch off the effect
- Use the StemsFX button to switch off effects application to stems (and go back to the default of the entire audio)
geposted Fri 05 May 23 @ 3:05 am
Is there any word on this? It still happens on v2023-m b7555.
geposted Tue 30 May 23 @ 1:41 am
Does the audio come back when using the paddles to turn effects on again?
geposted Tue 30 May 23 @ 6:28 am
No it doesn't, it plays the isolate stem with the effect. The deck itself stays in isolation mode for the Stem FX button for the entire session.
It's not as easily reproducible as I first thought - I consciously tried the steps again and it didn't reproduce, but it seems that I am always reproducing it by doing the first sequence (switch Stem FX to a particular part, perhaps removing some stem parts (melody and bass), activate the effect, switch Stem FX back to full song), optionally applying another effect on that deck, optionally switching to another pad mode (like Sampler to play a sample), then loading + bringing in a new song on another deck (this new deck is the one affected).
I also realize that the new deck a lot of the time has the Stem FX state on some random state (like applied to Vocal only or Melody only), that is different from the default (Effects applied to the entire track)
Perhaps relevant information: I have resetStemsOnLoad = Pads
geposted Wed 31 May 23 @ 3:00 am
Any follow up on this?
geposted Sat 17 Jun 23 @ 7:21 pm
So I'm almost guaranteed to get into this weird state for the stems 2.0 pad page every time I play (it happened last Friday when i accidentally hit the stems FX mode button (changing ot to vocals) then changing it back to full track FX mode with the same button, as it is a toggle switch for the different states.
Not trying to be annoying or anything but has anyone confirmed/reproduced this?
geposted Sat 24 Jun 23 @ 3:23 pm
Sorry for the delay, managed to test it out and found the issue.
The problem is the way effects are processed on the S11
-First of all, it won't be possible to use the hardware effects, since when hardware effects are used, the fx send/return channels are bypassed by the firmware. Because they are bypassed, VirtualDJ can't properly add the other stems back to the mix, and this is why you hear only the selected fx stem.
-Using software effects on stems currently works partially, however the fx send/return channels volume is different, so it doesn't exactly match up the sound correctly either, so you'll get a boost of the non-stems channels instead
-For the next update, it will work with software effects, but only when fxProcessing is set to pre-fader.
I'll have a look to see if software effects could work post-fader as well, but that might not be possible due to the mentioned volume difference
(Note that the hardware effects would still be post-fader, so that might be an acceptable trade-off (use the hardware effects for regular fx and the software fx for stems fx)
geposted Sat 24 Jun 23 @ 4:50 pm
@Adion thank for confirming the issue and this explanation. I guess I'll steer clear of stem fx with that mixer. Is this only specific to the S11 or is it a general external mixer problem?
geposted Sun 25 Jun 23 @ 1:41 pm
It's likely a problem with any mixer that uses fx send/return channels, although I'm not sure how common it is that the levels are different for the send/return channels.
The dynamic turning on/off of the fx send/return channels further complicates the problem, but not sure either how common that is.
I think it's the same for the S9. The DJM-900NXS2 uses a single send/return channel, so that might be even more random depending on the selected channel.
For the FLX10 Pioneer decided to finally go back to master/headphones output from the computer, which gives full control to the software and would not suffer from these issues.
Although it is a controller, it would be nice if they did the same for future mixers too.
geposted Sun 25 Jun 23 @ 2:28 pm
It seems that this problem has not been patched yet. Just stunbled into this problem right now with my REV 7, tried using the Stems FX and ended up having the parts bosted. I might try using the fx pre fader, but might have soo trade off regarding some pad FXs.
geposted 4 days ago @ 3:08 am
They can't really patch it in VDJ
Like explained above it's really a hardware "bug" (or rather an irritating side effect) on some controllers/mixers that uses a special way of handling FXs, so that VDJ has no control over it
geposted 4 days ago @ 5:58 am
I use that same pad page with my Rane 70 and haven't noted the jump referenced here. I have my software FX set to pre-fader. I use the paddles for the hardware effects (post-fader) and the pads for the Stem FX (pre-fader), and haven't noticed any issues. The only thing is I have to remember to set the FX back to post-fader when I use my SX2 or when I practice with no mixer or controller hooked up.
geposted 3 days ago @ 1:37 pm
