Some notes about my experience:
- I tried it on a (old) Laptop with a i7-4720HQ with GTX 965M (2GB)
couldn't get i working, only prossesing on th CPU works and takes way to long
- On a PC with Ryzen 5 2600 and GTX 1050Ti (4GB) it works at a resonable speed
- Always make sure to have the latests Geforce Driver
- The limiting factor on the 1050Ti seems to be the VRAM, so I guess 6GB or more a to recommend
(Tested with a 5min. 16-Bit FLAC file)
Comment you experience with hardware specs
geposted Fri 05 May 23 @ 4:40 pm
