Topic: Filter Folder Question
Guessing there is away to do this, but I just don't see it. I'd like to set up a Filter Folder to show only songs with ***** (5 Stars). If this is possible, it is not obvious... :(
geposted Sat 06 May 23 @ 2:27 am
Rating != *****
so when I enter this, it doesn't "stick".
If I go back to Edit this filter, what I see when I return is this:
works for me:
Only shows tracks with 5 stars in the filter folder.
win 10
7547
You also need to check this setting
So in my case, adding FOLDER to the Scope broke this. Without the advanced settings, "ratings = 5" seems to be working for me.
Should be set to Folder Recursive
