Last night while DJing, I was having a huge problem with nothing staying in sync. basically sync works, but beatlock doesn't. which means if i have a track that has uneven tempo, or i am having it slowly reset to normal speed, the other deck won't stay in time.
it seems to have happened on my both my laptop and my PC at the same time. is it possibly something in the update, as i have looked at all the settings and checked through my mapping, and there is no obvious solution.
geposted Sun 07 May 23 @ 2:49 pm
i went back to an old build and it works normally again.
geposted Sun 07 May 23 @ 3:42 pm
My beatlock isn't working
geposted Sun 07 May 23 @ 11:52 pm
I agree - beatlock doesn't appear to be working in the latest EA release
Or rather, it seems to work like pitch_lock
geposted Mon 08 May 23 @ 1:30 am
I can confirm that it's working in latest Early Access release (build 7555)
geposted Mon 08 May 23 @ 6:50 am
