Topic: Change beat grid of one deck using keyboard
Hi,
I'm trying to figure out how to map the keyboard that I can change the beat grid or the left deck or the right deck.
I've tried these commands:
Deck 1 set_beatgrid
Deck 1 adjust_cbg 0.5%
Both options change the beat grid on both decks though. Can anybody help me with this? I can't find it in the forums.
Thanks in advance!
geposted Tue 09 May 23 @ 5:21 am
That's not correct
Deck 1 adjust_cbg -0.5%
and
Deck 1 adjust_cbg +0.5%
only adjust deck 1
Thanks for your reply. I changed it, but unfortunately it still slides both beat grids
Well.. A simple restart did the trick. Your command works now, thanks!
