So last night, I came across a weird issue and have no idea how I have done it or why it's doing it. So whenever I use my high's mids or lows filters, it changes the pitch like I am using the pitch control, it only happens on deck one, any idea how to turn that off -
Gyazo of the problem https://gyazo.com/3165680454e6ac06174c631fc554833c
You can see filter, beat and vocals messing with the pitch.
VDJ v2023 b7482 (paid pro)
Pioneer DDJ-200 controller
(windows 10 pro)
*Edit* So it only does it with my controller plugged in, it doesn't do it if I use mouse and keyboard to control them.
(windows 10 pro)
geposted Sat 13 May 23 @ 12:44 am
*bumping this because the issue is annoying as hell* - seems the latest update has fixed the issue, but it is still there slightly, but manageable.
geposted Mon 15 May 23 @ 5:34 am
Is your controller on the factory default mapping?
geposted Mon 15 May 23 @ 5:54 am
yeah, its compatible with vdj so it suing the mapping on that, its only just started doing it the past few nights, no idea what happened, I didn't change anything
geposted Mon 15 May 23 @ 7:13 am
Is it acting like this on both Decks ?
If you goto VirtualDJ Settings, MAPPING tab, select your controller, you should see the names of the knobs you move on the right-side (Key Learn window).
When you move one of the EQ knobs, do you see other keys appearing there (e.g. the PITCH key) along with the EQ knobs ? If so, it looks like a faulty device
geposted Mon 15 May 23 @ 9:31 am
