this morning after the b7555 update all playlists and virtual folders disappeared from the browser. vdjfolders files are regularly in place. even resetting all virtualdj new virtual folders are not kept on closing. impossible to restore from backup with a whole series of errors.
geposted Sun 14 May 23 @ 9:40 am
i tried to reinstall everything and it shows me an error 2503 and then 2502, the setup fails and closes. I don't understand what's wrong.
geposted Sun 14 May 23 @ 9:49 am
The VirtualDJ Folder on the System-Volume has a new location. Copy your old files and Folders to the new location.
Normally this only happens with a new installation.
You can open the folder by click the small cog an the right bottom of the Options page.
![](https://www.virtualdj.com/img/380380/68563/Screenshot%202023-04-22%20075336.png)
geposted Sun 14 May 23 @ 10:12 am
I solved by opening virtualdj setting run as administrator. all playlists and virtual folders appear regularly. however I don't understand what it depends on, the previous build I never had to touch any particular setting. I add that only the 'folders' folder was not loaded while 'plugins' 'mappers' etc all regular
geposted Mon 15 May 23 @ 2:02 pm
