Hi!
I've been looking for a way for quite some time to set up my webcam in such a way that I can virtually change the background (similar to Microsoft Teams) and only see my face, for example. Is that possible and if so, how exactly?
Thanks
Thanks
geposted Sun 14 May 23 @ 10:13 am
use the webcam controls for chromakey, wear a green shirt, with a greenscreen, and your disembodied head would be floating in space with whatever background you set
geposted Sun 14 May 23 @ 10:40 am
thank you - and how can I set a background? It´s only possible when I select "Dual-Source Mixing"?
geposted Sun 14 May 23 @ 1:44 pm
Play Video or start a Slideshow at the same time.
geposted Sun 14 May 23 @ 2:12 pm
https://www.youtube.com/watch?v=XcoVAS3p2jU
I´m looking for exactly this - does someone know how it works?
geposted Sun 14 May 23 @ 3:42 pm
Er hat auch nenn Greenscreen. Sieht man in dem Bild gut. Arme / Gesicht reflektieren ein leichtes grün.
Die Clips im Hintergrund sind Videos (Slideshow kann auch Videos wiedergeben) oder Shaders.
geposted Sun 14 May 23 @ 4:12 pm
In my opinion and experience, the chromakey / green screen in VDJ is poor.
With only one knob to adjust, it can be very hard to achieve good results.
This is why I use Resolume software for the chromakey, as it has way more adjustment / fine tuning available. I then feed Resolume into VDJ via Spout.
There are plenty of other options available too, even software supplied with the webcams.
geposted Sun 14 May 23 @ 5:15 pm
Sorry for the german post. The Topic Creator has the same Topic in the german Forum. I answer to the wrong Post.
geposted Sun 14 May 23 @ 6:17 pm
