Topic: Rane 4 or Pioneer Flex 10
Looking to get a new controller. Do you feel the Rane 4 or Pioneer Flex 10 works better with VDJ? Or is there another controller that you would go with?
PS The mic input is essential for me also.
Cheers!
Robby
geposted Wed 17 May 23 @ 6:28 pm
Denon Prime 4 or Denon sc4
I just saw someone raving about Prime 4. Sounds pretty awesome. Hows the mics?
Also do you like the Prime 4 better?
I am a Pioneer user, but would go for the Denon Prime 4 if I had the money.
Just by looking at them and for example compare the better in/outputs with xlr , and more knobs on each channel to control so much more than the others makes it the winner for me.
If I bought it, I surely would make a good custom mapping to suit my work :)
There has been a long standing issue with the Prime 4 where the XLR outputs sound bad compared to the RCA. Not sure if Denon ever fixed that but it woukd be a showstopper for me.
