Hello :) hope you are having a good day :).
I just got myself a DJ2GO Touch and I'm playing with some sampler banks but I don't want the samples playing in the headphones like they do when you select output master. and if I select trigger deck it's often not the deck that is currently playing.
So I was wondering if there is a script that can check to see if the crossfader is above or below 50% and set the active deck accordingly?
Thx :)
Thx :)
geposted Thu 18 May 23 @ 3:10 pm
