Hello,
Do you know how to remove this cable ?
.png)
If I just have to push or I need to take care of it ?
It's the motherboard of the Numark Mixtrack Pro FX. I want to change the crossfader.
Thank you
.png)
Thank you
geposted Thu 25 May 23 @ 9:32 pm
Hey guys
You can close the ticket. I found the solution
First : pull the black part (not to the top, but from the same direction of the blue part)
Then : pull the blue part.
geposted Thu 25 May 23 @ 9:55 pm
Completely off topic re: vdj but I'm interested in how and what your are replacing your cross fader with, as I have the same controller.
I'm assuming it's s numark replacement part rather than an upgrade to say an innofader?
geposted Sun 28 May 23 @ 7:02 pm
