Hey folks, I just connected my two controllers (Gemini MDJ 500 and Gemini CDJ 650) via midi to my computer. Their outputs are connected to my mixer.
I set the mapping as you can see on the picture for the Gemini CDJ 650 to deck 2
The other controller MDJ 500 is set to deck 1.
The audio output are set as you can see on the picture
Unfortunately my deck 2 is only playing in mono while the other deck 1 is playing in stereo.
I checked the cables and they are working just fine.
Is there any solution to solve this problem?
Thanks in advance.
.The other controller MDJ 500 is set to deck 1.
.Unfortunately my deck 2 is only playing in mono while the other deck 1 is playing in stereo.
Thanks in advance.
geposted Sat 27 May 23 @ 11:36 am
