Topic: XP1 and XP2 pad flashing when loading track?
Hello everyone,
Yesterday I noticed this "flashing" of the pads every time a song is loaded. they flash on the left side if the song is loaded on deck 1 and on the right side if the song is loaded on deck 2. I tried, pc, mac, resetting Virtual DJ settings but it didn't help. It happens with both xp1 and xp2 and with different usb cables. I had to go way back in i versions of Virtual DJ to fix this because I was sure it didn't happen before. Can anyone of you who have xp1 or xp2 try and confirm? You know how to fix or is it normal now because something has changed?
Thank you
geposted Sun 28 May 23 @ 3:06 pm
Like you have probably learned by now from the FB group, this is how it's supposed to work
The pulse indicates that the pads now triggers on a new track
I managed to solve it, a command of the mapping had inexplicably gone from off to on and this command activates or deactivates the flashing.
